[GRASS-dev] [GRASS GIS] #2503: wxdigit: wrong undo & redo
trac at osgeo.org
Tue Dec 9 01:34:17 PST 2014
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords: digitizer
Platform: Unspecified | Cpu: Unspecified
Comment(by mlennert):
Replying to [comment:12 mmetz]:
> Replying to [comment:11 mmetz]:
> > Replying to [comment:10 mlennert]:
> > > Replying to [comment:9 mmetz]:
> > > > Replying to [comment:8 mlennert]:
> > > > > Replying to [comment:7 mmetz]:
> > > > > > The list of updated lines as returned by the vector lib was
incomplete. Fixed in r63349,50 (trunk, relbr70), please test.
> > > > > Still not quite:
[http://tomahawk.ulb.ac.be/moritz/wxdigit_undo_redo4.ogv].
> > > > > If you need more explanation, I can write some, but right now I
have to go.
> > > > Got it. This bug (yet another one) should be fixed in r63364,5
(trunk only).
> > > Wow, great detective work there ! As of now I haven't been able to
find any other bugs linked to undo/redo. This fix should be backported to
grass7release and then I think we can close this bug for now.
> > I do not fully understand 1) why the fix is needed, 2) why the fix is
working.
> The fix is working because V2_rewrite_line_nat() does not work as
expected, it does not rewrite, it always deletes the line and writes out a
new line (COW). All fixes related to this ticket have been backported to
relbr70 in r63397,8 after testing.
You just signficantly improved the use of the digitizer, thanks a lot !
Just one question concerning r63398: shouldn't the code just be deleted
instead of using 'if 0' ?
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2503#comment:13>
