[GRASS-dev] [GRASS GIS] #2509: d.mon output overwrite
trac at osgeo.org
Wed Dec 10 13:15:02 PST 2014
Reporter: martinl | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: Display | Version: unspecified
Keywords: d.mon | Platform: Unspecified
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:6 neteler]:
> > This might be something different but probably related. Call of
`d.rast` when `d.mon wx0` is active causes creation of `map.png` in the
current directory:
> > I observe this for a long time already but until recently I wasn't
able to find a cause.
> I tried as well - must be display driver related of course. A rather
annoying problem...
related to this issue something changed in display architecture (probably
Glynn will know more), now you don't need to start any monitor to render
data
d.mon -p
No monitor selected
d.vect streams --v
Using display driver <cairo>...
cairo: collecting to file 'map.png'
cairo: image size 640x480
Plotting...
8554 lines plotted
d.vect complete.
I would see this behaviour as misleading from the user point of view. In
GRASS 7.0:
d.mon -p
No monitor selected
d.vect streams
ERROR: No graphics device selected. Use d.mon to select graphics device.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2509#comment:9>
