[GRASS-dev] On integrating i.fusion.hpf into i.pansharpen
Yann Chemin
ychemin at gmail.com
Sat Dec 20 10:43:28 PST 2014
Would it make sense to let it be separate?
On Dec 20, 2014 11:52 PM, "Nikos Alexandris" <nik at nikosalexandris.net>
wrote:
> Dear all,
> I want to integrate the "AHPF" fusion algorithm, <i.fusion.hpf> [0], into
> <i.pansharpen> [1]. And I need some assistance.
> 1. <i.pansharpen> has the following, simple, interface:
> i.pansharpen [-sl] red=name green=name blue=name pan=name
> output=basename method=value [--overwrite] [--help] [--verbose]
> [--quiet] [--ui]
> plus
> Flags:
> -s Serial processing rather than parallel processing
> -l Rebalance blue channel for LANDSAT
> while the HPF implementation looks like:
> i.fusion.hpf [-l2c] pan=filename msx=filename(s)[,filename(s),...]
> outputsuffix=suffix string [ratio=rational number] [center=string]
> [center2=string] [modulation=string] [modulation2=string]
> [trim=rational number] [--overwrite] [--help] [--verbose] [--quiet]
> [--ui]
> plus
> Flags:
> -l Linearly match histogram of Pan-sharpened output to Multi-Spectral
> input
> -2 2-Pass Processing (recommended) for large resolution ratio (>=5.5)
> -c Match color table of Pan-Sharpened output to Multi-Spectral input
> While the first module appears to be simple and straightforward, it has
> its limitations (rgb required, underlying ihs method restricted to 8-bit
> data). The second module appears complex, but it works right away by simply
> feeding a pan and a multi-spectral band (or bands) and, offers many
> fine-tuning options.
> 2. <i.pansharpen> has the R-G-B logic hardcoded (one pan and three
> multi-spectral bands required), while <i.fusion.hpf> will work simply with
> a pan and only one or any number of multiple low-resolution bands.
> If all of the fine-tuning options for HPF will be merged into
> i.pansharpen, it'll get "heavy" and complex. I am asking for help to
> design the integration (not for the actual coding). Any ideas?
> Thank you, Nikos
> [0] <https://github.com/NikosAlexandris/i.fusion.hpf>
> [1] <http://grass.osgeo.org/grass70/manuals/i.pansharpen.html>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141221/d366c3c2/attachment.html>
