[GRASS-dev] On integrating i.fusion.hpf into i.pansharpen
Nikos Alexandris
nik at nikosalexandris.net
Sun Dec 21 04:28:02 PST 2014
Helmut Kudrnovsky wrote:
> guisections for each algorithm?
> "A "guisection" field may be added to each option and flag to specify
> that
> the options should appear in multiple tabs in the auto-generated
> GUI."[1]
> [1] http://grass.osgeo.org/grass70/manuals/g.parser.html
This will help for the GUI. But the command, wildly guessing, still
will be something like:
i.pansharpen [-slh2c] pan=name red=name green=name blue=name
msx=name[,name(s),...] output=suffix method=value [ratio=rational
number] [center=string] [center2=string] [modulation=string]
[modulation2=string]
[trim=rational number] [--overwrite] [--help] [--verbose] [--quiet]
[--ui]
where none of red, green, blue or msx will be required!? How would
that look like?
Nikos
