[GRASS-dev] [GRASS GIS] #2403: cairo driver fails to create surface
trac at osgeo.org
Tue Dec 23 15:05:53 PST 2014
Reporter: martinl | Owner: martinl
Type: defect | Status: closed
Priority: major | Milestone: 7.0.0
Component: Display | Version: unspecified
Resolution: fixed | Keywords: cairo, resolution, surface
Platform: Linux | Cpu: x86-64
Comment(by neteler):
Replying to [comment:9 glynn]:
> r63582 makes the cairo driver behave almost identically to the PNG
driver.
> For reasons which I've been unable to determine so far, the result is
one destination pixel wider than with the PNG driver.
Not sure if related but here I remember ticket #72.
> Ultimately, the code should be modified to use an intermediate surface
which has the same dimensions as the destination rectangle, to avoid the
overhead of copying the (empty) borders.
Should the ticket be reopened for this?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2403#comment:14>
