[GRASS-dev] [GRASS GIS] #2513: v.colors freezes using the pg driver and attr
GRASS GIS trac at osgeo.org
Wed Dec 24 01:06:29 PST 2014
 Reporter:  jamesp670                |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  normal                   |   Milestone:  7.0.0
Component:  Database                 |     Version:  svn-trunk
 Keywords:  freeze in G_fatal_error  |    Platform:  Linux
      Cpu:  x86-64                   |
Description changed by martinl:
Old description:
> Hi Grass Devs,
> You've got a big fan in me.  I acknowledged GRASS on my AGU (see agu.org)
> poster this year and I'll make sure it's a cite next year.
> I have a bug report.  This is getting complex and perhaps you can help?
> The setup:
> My uname output:
> : GRASS 7.0.0svn (rlis-master-for-seven):~ > uname -a
> : Linux login.cluster 2.6.32-431.17.1.el6.x86_64 #1 SMP Wed May 7
> 23:32:49 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
> I built grass from source, using primarily deps supplied by
>    : yum install http://yum.postgresql.org/9.3/redhat/rhel-6-x86_64/\
>    : pgdg-redhat93-9.3-1.noarch.rpm
> The build is painless.  GRASS works great, except for this bug.
> I run GRASS v.colors to obtain a color map for TIGER census, as in:
> : GRASS 7.0.0svn (rlis-master-for-seven):~ > v.colors --verbose
> map=tract2010censusdp1_clipped_02 column=popden10 layer=1
> rgb_column=GRASSRGB color=grey
> What I expect:
> GRASSRGB column is created and populated with greyscale values.
> What happens instead, is that v.colors freezes.  Specifically, I see this
> sequence:
> : Option <column> given, assuming <use=attr>...
> : Converting color rules into categories...
> : Writing color rules...
> : DBMI-PostgreSQL driver error:
> : Unable to execute:
> : ALTER TABLE tract2010censusdp1_clipped_02 ADD COLUMN GRASSRGB
> VARCHAR(11)
> : ERROR:  column "grassrgb" of relation "tract2010censusdp1_clipped_02"
> already exists
> VARCHAR(11)
> already exists
> : ERROR: Unable to add column <GRASSRGB> to table
> :        <tract2010censusdp1_clipped_02>
> : no database is open
> :   C-c C-c
> Where the C-c C-c is, I am tapping C-c to break the task, which is
> blatently frozen.
> I've debugged it.  The sequence of events is:
> : print "no database is open"
> : db_shutdown_driver(driver=00661C40)
> : doing waitpid(pid=1583)
> : [freeze]
> During the freeze, proc 1583 is still running, and it's a db/pg process.
> If I "kill 1583", the v.colors job ends immediately with no additional
> output,
> as in
> : [I kill the db/pg process by hand]
> I've tried v.colors in the trunk and release SVN branches.  The layer is
> fine,
> I can query it, view attributes just fine.  db.test output looks fine.
> It's
> 100% reproducable.
> I build from source, debug with gdb, insert print statements.  That's
> what got
> me this far, but now this IPC with the grass-7.0.0svn/driver/db/pg
> process is
> getting pretty complex.  If I had to hazard a guess, I'd say that closing
> the
> communication FILEs in shutdown.c should cause the db/pg process to end.
> It
> is not for some reason.  That then also begs the question of why the
> shutdown
> is called before the colors are written at all.  The stack is:
> : (gdb) where
> : ,#0  0x0000003ab72ac8ce in waitpid () from /lib64/libc.so.6
> : ,#1  0x00002aaaab17f3ad in G_wait (i_pid=28458) at spawn.c:981
> : ,#2  0x00002aaaaad37348 in db_shutdown_driver (driver=0x661ec0) at
> shutdown.c:59
> : ,#3  0x00002aaaaad35e60 in error_handler_driver (p=0x661ec0) at
> handler.c:24
> : ,#4  0x00002aaaab1630ad in G__call_error_handlers () at handler.c:108
> : ,#5  0x00002aaaab15ee93 in G_fatal_error (
> :     msg=0x405368 "Unable to add column <%s> to table <%s>") at
> error.c:176
> : ,#6  0x00000000004042b1 in write_rgb_values (Map=0x7fffffffcfb0,
> layer=1,
> :     column_name=0x654830 "GRASSRGB", colors=0x7fffffffce90) at
> write_rgb.c:37
> : ,#7  0x0000000000402f83 in main (argc=7, argv=0x7fffffffd988) at
> main.c:350
> If I delete grassrgb by hand, v.colors does return neatly and works
> great, as in:
> : psql (9.3.5)
> : => alter table tract2010censusdp1_clipped_02 drop column grassrgb;
> : ALTER TABLE
> then
> h: Option <column> given, assuming <use=attr>...
> : Column <GRASSRGB> added to table <tract2010censusdp1_clipped_02>
> : Color table for vector map <tract2010censusdp1_clipped_02 at PERMANENT>
> set to
> : 'grey'
> The content of GRASSRGB looks fine after that.
> Removing the color table using -r before running doesn't work, I get
> : GRASS 7.0.0svn (rlis-master-for-seven):~ > v.colors -r
> map=tract2010censusdp1_clipped_02 rgb_column=GRASSRGB
> : WARNING: Color table of vector map <tract2010censusdp1_clipped_02> not
> :          found
> rgb_column=GRASSRGB color=bgyr
> : [freeze]
> I obviously don't understand the difference between the color table and
> the rgb_column.  v.colors seems to
> lack the usual --overwrite.
> So I have a workaround: remove the column by manual sql entry before
> running
> v.colors.  The freeze is obviously a bug, and there seems to be a lack of
> clarity RE: the lack of --overwrite and the use of -r.
> How you can reproduce this at home:
> 1. Open http://rlisdiscovery.oregonmetro.gov/
> 2. CLick on "Download" for 2000 Block Groups.
> 3. Save it into ~/tmp
> 4. unzip blockgrp2000.zip
> 5. grass70 -gui
> 6. Location Wizard
> 7. Project Location: rlus-bug-report
> 8. Read projection ... data file
> 9. Georef file: blockgrp2000.shp
> 10. Do *not* Import the data (although that is a nice grass 7 touch
> there!)
> 11. start grass.
> 12. db.connect driver=pg database="host=myhost,dbname=mydb"
>     [substitute your database of course]
> 13. v.in.ogr dsn=/home/powellj/tmp/blockgrp2000.shp output=blockgrp2000
>     (4385 primitives imported in about a minute).
> 14. v.colors --verbose map=blockgrp2000 column=pop08 layer=1
>                 [works great, finishes in < 1s]
> 15. Repeat step 14.  It freezes immediately, reading "no database is
> open".
New description:
 Hi Grass Devs,
 The setup:
 My uname output:
 : Linux login.cluster 2.6.32-431.17.1.el6.x86_64 #1 SMP Wed May 7 23:32:49
 What I expect:
 sequence:
 VARCHAR(11)
 already exists
 VARCHAR(11)
 already exists
 :   C-c C-c
 blatently frozen.
 : [freeze]
 output,
 as in
 fine,
 It's
 100% reproducable.
 I build from source, debug with gdb, insert print statements.  That's what
 got
 me this far, but now this IPC with the grass-7.0.0svn/driver/db/pg process
 is
 the
 It
 shutdown
 : (gdb) where
 shutdown.c:59
 handler.c:24
 error.c:176
 layer=1,
 write_rgb.c:37
 main.c:350
 If I delete grassrgb by hand, v.colors does return neatly and works great,
 as in:
 : psql (9.3.5)
 : ALTER TABLE
 then
 : Color table for vector map <tract2010censusdp1_clipped_02 at PERMANENT> set
 to
 : 'grey'
 :          found
 : [freeze]
 running
 5. grass70 -gui
 6. Location Wizard
 there!)
 11. start grass.
 open".
Ticket URL: <http://trac.osgeo.org/grass/ticket/2513#comment:2>
