[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
GRASS GIS trac at osgeo.org
Wed Dec 24 09:34:20 PST 2014
 Reporter:  martinl               |       Owner:  grass-dev@…
     Type:  task                  |      Status:  new
 Priority:  blocker               |   Milestone:  7.0.0
Component:  Default               |     Version:  unspecified
 Keywords:  standardized options  |    Platform:  Unspecified
      Cpu:  Unspecified           |
Comment(by cmbarton):
 Replying to [comment:164 martinl]:
 > Replying to [comment:163 martinl]:
 > > > ncolumn   Node cost column
 > > >           Node cost column (number)
 > > This is more significant issue, all of v.net modules uses various
 shortened options
 > > > afcolumn  Arc forward/both direction(s) cost column (number)
 > > > acolumn   Arcs' cost column (for both directions)
 > > > abcolumn  Arc backward direction cost column (number)
 > > >                   EXPERIMENTAL: Arc backward direction cost column
 (number)
 > > see my note about `v.net` modules above
 > I went though v.net modules and renamed
 > alayer -> arc_layer
 > nlayer -> node_layer
 > type -> arc_type
 > ccats -> center_cats
 > ncolumn -> node_column
 > afcolumn -> arc_column
 > abcolumn -> arc_backward_column
 > tcats -> terminal_cats
 > nsp -> npoints
 > coordinate -> coordinates
 > vis -> visibility
 Thanks much. These are a great improvement. IIRC, the vector overlay/query
 modules could use something similar. Perhaps already done as I've had no
 time to investigate at the end of semester here. This is a lot of work I
 realize but greatly appreciated.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:166>
