[GRASS-dev] [GRASS GIS] #2509: d.mon output overwrite
trac at osgeo.org
Thu Dec 25 01:37:38 PST 2014
Reporter: martinl | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: Display | Version: unspecified
Keywords: d.mon | Platform: Unspecified
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:18 glynn]:
> > If it matters, more people are interested in a working d.mon/command
line approach:
> I don't doubt it. I've tried to have discussions on such things in the
past. But some people prefer to just implement hacks like $MONITOR without
any discussion. Ultimately, that's likely to be counter-productive in
terms of any reasonable solution.
> FWIW, I don't actually object to requiring $GRASS_RENDER_IMMEDIATE to be
set. I do object to it being done by /fait accompli/. I'm also less than
keen on the way that wxGUI seems to be
Let's start with fundamental points:
* some users like monitor concept (GUI monitors, and "file-based"
monitors), we should keep it since there is relatively strong request to
have them
* direct rendering is a nice feature, but should be enabled only on
demand (eg. when $GRASS_RENDER_IMMEDIATE is set), otherwise the most of
users will be confused why display modules are producing `map.png` (or
`map.ps`...) files in the current directory just without asking
Can we have consensus on these points above? If so let's focus on
implementation of the second issue and after releasing 7.0 we can discuss
better implementation of monitors rather than using hacks like $MONITOR.
Make sense to you?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2509#comment:19>
