[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
trac at osgeo.org
Thu Dec 25 03:56:00 PST 2014
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:169 glynn]:
> My intention is to modify the code which calls match_option()
(set_option() and check_string()) to record which options are matched. If
one option is a prefix of all of the others, the string will be considered
to unambiguously match that option. If the match is ambiguous, we now have
a list of which options matched, which can be used for the error message.
This change is implemented in r63744.
Currently, an ambiguous match for an option key lists the matches, but an
ambiguous match for a value (opt->options) doesn't (as the error message
is generated by the caller).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:170>
