[GRASS-dev] [GRASS GIS] #2509: d.mon output overwrite
trac at osgeo.org
Thu Dec 25 06:41:57 PST 2014
Reporter: martinl | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: Display | Version: unspecified
Keywords: d.mon | Platform: Unspecified
Cpu: Unspecified |
Comment(by wenzeslaus):
Hi Glynn and Martin, one of the biggest problems of the old state was that
it was not documented, so it was not clear what are the possibilities and
common usage patterns. Can you please documented as much as you can now?
For example, it would be good to document how to effectively use the
system from Python scripts and from external applications such as QGIS
(which may not posses features such as `d.rast.num`). I think the proper
place would be `displayintro.html` file.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2509#comment:22>
