[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
trac at osgeo.org
Fri Dec 26 12:31:15 PST 2014
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:175 wenzeslaus]:
> If I understand correctly, we still want to use full option names for
GRASS code (and perhaps documentation) and to advise it for user scripts.
Indeed.
The main issues I see with abbreviations are:
1. Searching for use of an option name (grep, Ctrl+F, etc) will miss
abbreviations.
2. Abbreviations make code harder to understand for people who aren't
fluent in English.
> In this case it would be good to have a way to proof that the full
option names are used, something like an environmental variable
`GRASS_FULL_OPTION_NAMES` which would switch off the advanced
word/character matching and `renamed_options` so that only full names
would be considered as valid.
r63765 generates a warning if GRASS_FULL_OPTION_NAMES is set (to anything)
and the found string isn't an exact match for the given string.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:176>
