[GRASS-dev] [GRASS GIS] #2505: v.build.polylines options aren't working
trac at osgeo.org
Fri Dec 26 14:35:30 PST 2014
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Vector | Version: svn-releasebranch70
Keywords: v.build.polylines | Platform: All
Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:1 mmetz]:
> Replying to [ticket:2505 hellik]:
> `cats=no` was indeed not working, fixed in r63321,2 (trunk, relbr70).
Should this go also into GRASS 6?
> `v.build.polylines` is indeed copying all attribute tables as is from
input to output, but the categories are processed according to the cats
option. This means that the attribute table(s) can contain spurious
entries that do not match any output feature. Other (not all) modules also
copy attribute tables from input to output as is, without filtering.
Usually, this does not harm and is not even noticeable.
Is this ticket solved?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2505#comment:2>
