[GRASS-dev] [GRASS GIS] #2283: wingrass: failure when loading addons
GRASS GIS trac at osgeo.org
Sat Dec 27 07:11:27 PST 2014
 Reporter:  martinl           |       Owner:  grass-dev@…
     Type:  task              |      Status:  new
 Priority:  critical          |   Milestone:  7.0.0
Component:  Addons            |     Version:  svn-trunk
 Keywords:  wingrass, launch  |    Platform:  MSWindows 2K
      Cpu:  Unspecified       |
Comment(by hellik):
 Replying to [comment:5 hellik]:
 > Replying to [comment:1 wenzeslaus]:
 > > Can you please elaborate more on how the addons are handled and what
 actually went wrong? I tis not clear to me if this is something which
 happens all the time or just when there is error in the source code.
 > the error message should contain something like: "you are trying to use
 an addon built upon an another/older version of winGRASS; please update
 your addon by reinstalling".
 I've seen that in C:\Users\xxxxx\AppData\Roaming\GRASS7\addons\modules.xml
 there is following entry:
         <libgis revision="62177" />
 using this information for a wxGUI-startup message which indicates to a
 needed addon update?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2283#comment:6>
