[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
trac at osgeo.org
Sat Dec 27 20:00:30 PST 2014
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
Cpu: Unspecified |
Comment(by wenzeslaus):
Continuing in what I wrote in comment:17 and following ones changed
G7:r.rgb in the way that fixed number of outputs handled by basename was
replaced by specific options. This is not only more explicit but also fits
more to the context when same rasters are used as input and in case of
`r.rgb` allows to request only some outputs.
Old `r.rgb`:
Usage:
r.rgb input=name [output=basename] [--overwrite] [--help] [--verbose]
[--quiet] [--ui]
Parameters:
input Name of input raster map
output Name of output basename raster map(s)
Default: input
New `r.rgb`:
Usage:
r.rgb input=name red=name green=name blue=name [--overwrite]
[--help] [--verbose] [--quiet] [--ui]
Parameters:
red Red channel raster map name
green Green channel raster map name
blue Blue channel raster map name
If somebody would like to learn how to write a test, this is a great
opportunity. On might do something like:
r.composite r=lsat7_2002_10 g=lsat7_2002_30 b=lsat7_2002_50 o=lsat_comp
r.rgb i=lsat_comp r=lsat7_2002_10 g=lsat7_2002_30 b=lsat7_2002_50
And then test difference of old and new maps. The results might not be
identical but should be close to each other. Another tests can check if
only one map is created when one map is requested.
I cannot work on this more but similar change as I did for `r.rgb` could
be done for G7:r.blend too. It also has an `output` option which is a
"basename for red, green and blue output raster maps".
There are some other modules I'm not completely sure about such as
G7:i.pansharpen and G7:i.topo.corr.
Some other seems that they don't need this change (e.g., G7:i.pca,
G7:i.landsat.toar, G7:i.landsat.acca, and G7:i.tasscap) because the number
of outputs is variable. However, I'm not sure how the suffixes are
generated, sometimes it seems that they are even expected on the input.
Standard basename separator (underscore, #2136) should be used in all
cases otherwise it is not really standard, now many of them are probably
using dot.
Last issue I know about is G7:r.texture where the number of outputs
depends on number of requested textures. G7:r.neighbors actually solves
this issue by using output not as a basename but as multiple and
requesting as many outputs as requested methods.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:182>
