[GRASS-dev] [GRASS GIS] #2516: r.stream.distance elevation above streams produces unexpected null values
GRASS GIS trac at osgeo.org
Sun Dec 28 06:32:20 PST 2014
 Reporter:  madi                        |       Owner:  grass-dev@…
     Type:  defect                      |      Status:  new
 Priority:  normal                      |   Milestone:  7.1.0
Component:  Raster                      |     Version:  svn-trunk
 Keywords:  r.stream,r.stream.distance  |    Platform:  Unspecified
      Cpu:  Unspecified                 |
 As written in the summary. The commands i used:
 r.watershed -a -b elevation=dem threshold=1500 accumulation=accum
 drainage=drainage stream=stream1500
 r.stream.distance stream_rast=stream1500 direction=drainage elevation=dem
 method=downstream difference=elev2stream
 elev2stream map has several null values. I tried with 2 different dems,
 srtm and aster2, on senegal area.
 Linux Fedora 20, GRASS 7.1.svn (r63559)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2516>
