[GRASS-dev] [GRASS GIS] #2517: d.vect.thematic won't write grassrgb values, ERROR: You must provide <sql> or <input> option
GRASS GIS trac at osgeo.org
Sun Dec 28 23:43:20 PST 2014
or <input> option
  Reporter:  jamesp670  |       Owner:  grass-dev@…
      Type:  defect     |      Status:  closed
  Priority:  normal     |   Milestone:  7.0.0
 Component:  Vector     |     Version:  svn-releasebranch70
Resolution:  fixed      |    Keywords:  d.vect.thematic postgresql grassrgb
  Platform:  Linux      |         Cpu:  x86-64
Changes (by neteler):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Good catch. I was able to reproduce the error with the North Carolina
 dataset (needed for actually fixing it):
 g.region vector=censusblk_swwake
 d.mon wx0
 d.vect.thematic -f -s map=censusblk_swwake column=TOTAL_POP
 themetype=graduated_colors \
   themecalc=custom_breaks breakpoints="0 500 1000 1500 2000 5000 10000
 15000 20000 25000" \
   colorscheme=blue-red monitor=none -u
 The db.execute call was incomplete. Fixed in r63803 and for relbranch70 in
 r63804.
 Closing, feel free to reopen if the problem persists.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2517#comment:1>
