[GRASS-dev] GRASS 7 - Ubuntu package build problem on Launchpad
Ivan Mincik ivan.mincik at gmail.com
Tue Dec 30 12:53:02 PST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 30.12.2014 18:58, Martin Landa wrote:
> Hi,
> 2014-12-30 14:30 GMT+01:00 Ivan Mincik <ivan.mincik at gmail.com>:
>> Hi Markus, this is a problem with dependency on Ubuntu GIS
>> repositories (I was writing about this earlier). You need to add
>> also Ubuntu GIS repositories in to your system using the same way
>> as you did for GRASS one. Another problem is that GRASS builds
>> depends on both 'ubuntugis-stable' and 'ubuntugis-unstable' which
>> can produce strange results.
> I changed that: grass-stable now depends on ubuntugis-stable and
> grass-devel on ubuntugis-unstable.
Martin, you might also update 'PPA description'. Maybe it could also
contain information how to add ubuntugis-stable|unstable packages.
Ivan Min?ík
ivan.mincik at gmail.com  GPG: 0x79529A1E
http://imincik.github.io/0x79529A1E.key
ivan.mincik at gista.sk     GPG: 0xD714B02C
http://imincik.github.io/0xD714B02C.key
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQEcBAEBAgAGBQJUoxCpAAoJEPfdLsR5UpoeYWkH/20xI7/fvafiCSBdj311U3Nv
P60zOBmaMdQbrMC1FhAUf3iyYOnjVAYIezFWXjgdoVpjsLtStiA9sMmAm/hVT/bT
7BPONqAN4lm9CTpce1D9yffLgkPnSW/kVFfCwEf2IEtEsivdupGDguZDZszjI2FQ
FAOQNhFYfiduC5Bf+yH/cAPMcaHnYcObIH8sqAcAACd+dBU4yAZwORoM9xgUQtQB
GBYOhuqz3YPmN8szug72FMLZXHNRH6SwomFstvg/uQagpM1S9zqOpnY/D0PFMGd9
EY7GU2rroetO+p/ynFDmcdAdvUDLtFjb/D2UIIyCmiHKEdjqOEi1Pf8cdVXseoA=
=8MP8
-----END PGP SIGNATURE-----
