[GRASS-dev] [SPAM?] Re: anyone compiled GRASS 7 on Mac Yosemite?
Anna Petrasova akratoc at ncsu.edu
Tue Dec 30 21:14:51 PST 2014
On Tue, Dec 30, 2014 at 3:49 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> Thanks. The versions I now have posted work fine with Yosemite. But I have
> not yet compiled under Yosemite.
> I have a couple of questions:
> What is: export VERSIONER_PYTHON_PREFER_32_BIT=yes?
> This is there to make it compile with 32bit wxPython 2.8. It depends which
Python you use, this works for the default Python on Mac OS:
https://developer.apple.com/library/mac/documentation/Darwin/Reference/ManPages/man1/python.1.html
> Also, is the SQLite problem something to do with Yosemite or something
> else?
> I haven't had time to look at it.
> I’ve also tried with wxPython 3 but it looks bad. So I’m still sticking
> with 2.8 (which is why we need the 32bit Python).
> Yes, there are still a lot of weird bugs, some of them must be fixed in
wxWidgets, some of them I tried to workaround. It would be good if you
could describe "looks bad", there might be some things which i can fix or
at least workaround.
> Here is what I do before compiling
> # This is for creating a distributable binary that is backward compatible
> to OSX 10.7
> export MACOSX_DEPLOYMENT_TARGET=10.7
> # This stuff is for making sure that it compiles using 32 bit Python
> export
> PATH="/Applications/python/bin32:/System/Library/Frameworks/Python.framework/Versions/2.7/bin:$PATH”
> # This is what I do for PROJ
> export NAD2BIN=/Library/Frameworks/PROJ.framework/Programs/nad2bin
> # This is (IIRC) for LAS tools compiling
> export CXX=g++
I think I haven't tried compiling with las tools yet.
> For the broken xml stuff, I’ve just saved versions of menudata.xml. and
> module_tree_menudata.xml. I drop these into the proper places before making
> a binary. Can I just run make from the source root from within GRASS to get
> the same thing?
It is enough to start GRASS session (without gui)  and then recompile (just
the wxpython part is enough) inside the session. That's what works for me.
I don't really try to understand why, it's apparently some problem with
makefiles and setting the right environmental variables. I thought we got
rid of this problem (Martin fixed something) but apparently not.
Anna
Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Dec 30, 2014, at 1:36 PM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> > Michael,
> > Anna compiled it for me.
> > Below is the configure and some notes. We had to run make for wxGUI from
> within GRASS and the vector attribute tables do not work
> > for me at the moment due to sqlite problems - we ran out of time to
> solve it.
> > We also used wxPython carbon 3 to see what kind of problems it would
> have - so some of the GUI panels are cut off so use 2.8
> > But otherwise it works great so it is worth doing - if you could provide
> GRASS7 binaries for yosemite that would be fantastic,
> > Anna is away but I have the machine with me so I can help or at least
> test.
> > Thanks for looking into it,
> > Helena
> > here are our notes:
> > ./configure \
> > --with-proj \
> > --with-x \
> > --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include \
> > --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib \
> > --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj \
> > --with-gdal=/Library/Frameworks/GDAL.Framework/Programs/gdal-config \
> --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> > --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
> --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include \
> > --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
> > --with-opengl=aqua \
> > --without-fftw \
> > --with-cairo
> --with-cairo-includes=/Library/Frameworks/cairo.framework/unix/include/cairo
> > --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib \
> > --with-cairo-ldflags="-lcairo" \
> > --with-freetype \
> --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2
> /Library/Frameworks/FreeType.framework/unix/include/ /opt/X11/include/" \
> > --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib \
> --with-geos=/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config
> > --with-sqlite \
> > --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib \
> --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include \
> > --with-macosx-archs="i386 x86_64"
> > # run before compilation: export VERSIONER_PYTHON_PREFER_32_BIT=yes
> > PATH="/Library/Frameworks/PROJ.framework/Versions/4/Programs:$PATH"
> > export PATH
> > wxPython carbon 3 has issues - use 2.8
> > Helena Mitasova
> > Professor at the Department of Marine,
> > Earth, and Atmospheric Sciences
> > and Center for Geospatial Analytics
> > North Carolina State University
> > Raleigh, NC 27695-8208
> > hmitaso at ncsu.edu
> > http://geospatial.ncsu.edu/osgeorel/
> > "All electronic mail messages in connection with State business which
> are sent to or received by this account are subject to the NC Public
> Records Law and may be disclosed to third parties.”
> > On Dec 30, 2014, at 2:51 PM, Michael Barton wrote:
> >> Has anyone yet tried to compile GRASS 7 on Mac Yosemite (AKA OS X
> 10.10)?
> >> I will update soon and try it. It would be nice to know if it compiles
> without any issues.
> >> Michael
> >> C. Michael Barton
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141231/a5392c0e/attachment-0001.html>
