[GRASS-dev] [GRASS GIS] #2521: d.vect.thematic, "Neither MONITOR (managed by d.mon command) nor" error
trac at osgeo.org
Wed Dec 31 23:30:21 PST 2014
Reporter: jamesp670 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-releasebranch70
Keywords: | Platform: Linux
Cpu: x86-64 |
What I expect:
My d.vect.thematic command,
d.vect.thematic -f -s --verbose
map=tract2010censusdp1_clipped_02 at PERMANENT column=popden10
themetype=graduated_colors themecalc=custom_breaks breakpoints="0 500 1000
1500 2000 5000 10000 1500\
0 20000 25000" colorscheme=green-red monitor=none -u
should work.
What happens:
GRASS 7.0.0svn (rlis-master-for-seven):~/projects/grass70_release >
!d.vect
Thematic map legend for column popden10 of map
Value range: 0.0 - 0.0103575
Color(R:G:B) Value
0:255:0 0 - 25000
ERROR: Neither MONITOR (managed by d.mon command) nor
GRASS_RENDER_IMMEDIATE (used for direct rendering) defined
^GTraceback (most recent call last):
File "/opt/yum-packages-installed-on-the-head-
node/tmp/local/grass-7.0.0svn/scripts/d.vect.thematic", line 1105, in
<module>
main()
node/tmp/local/grass-7.0.0svn/scripts/d.vect.thematic", line 733, in main
color = linecolor, fcolor = themecolor, icon = icon, size = ptsize)
node/tmp/local/grass-7.0.0svn/etc/python/grass/script/core.py", line 373,
in run_command
return handle_errors(returncode, returncode, args, kwargs)
node/tmp/local/grass-7.0.0svn/etc/python/grass/script/core.py", line 308,
in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['d.vect',
'map=tract2010censusdp1_clipped_02 at PERMANENT', 'layer=1',
'fcolor=0:255:0', 'color=none', 'type=area', 'icon=basic/circle', 'wher\
e=popden10 >= 0 AND popden10 <= 25000', 'size=5.0'] ended with error
Process ended with non-zero return code 1. See errors in the (error)
output.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2521>
