[GRASS-dev] [GRASS GIS] #2184: MySQL Error during 'v.in.ogr' in GRASS 7 SVN (2014-01-31)
trac at osgeo.org
Sat Feb 1 12:10:59 PST 2014
Reporter: justinzane | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: MySQL, OGR, import | Platform: Linux
Cpu: x86-64 |
It seems that there is a failure to properly quote the CREATE TABLE
command. Simply adding backticks "`" around the table name and all column
names allows the command to execute.
This looks like {{{create table `natural` (`cat` integer, `osm_id` varchar
(11), `name` varchar (48), `type` varchar (16));}}}.
Additionally, even though the CREATE TABLE failed and therefore the import
failed, a map is created and cannot be removed since its backing data
table never existed.
So, two separate issues need to be fixed. First the quoting. Second is the
need to wait until the import has succeeded before allocating a 'Map'.
v.in.ogr dsn=/home/justin/downloads/osm_CA/natural.shp
DBMI-MySQL driver error:
Unable to execute:
create table natural (cat integer, osm_id varchar ( 11 ),
name varchar ( 48 ), type varchar ( 16 ))
You have an error in your SQL syntax; check the manual that
corresponds to your MySQL server version for the right
syntax to use near 'natural (cat integer, osm_id varchar (
11 ), name varchar ( 48 ), type varchar (' at line 1
ERROR: Unable to create table: 'create table natural (cat integer, osm_id
varchar ( 11 ), name varchar ( 48 ), type varchar ( 16 ))'
Ticket URL: <http://trac.osgeo.org/grass/ticket/2184>
