[GRASS-dev] [GRASS GIS] #2185: Painfully Slow 'v.in.ogr' Vector Import
trac at osgeo.org
Sat Feb 1 12:39:21 PST 2014
Reporter: justinzane | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: import, OGR, performance | Platform: Linux
Cpu: Unspecified |
I'm trying to import shapefiles (in this case, OpenStreetMap data) into
GRASS (grass70-svn) using `v.in.ogr`; and it is '''painfully, brutally
slow'''. By slow, I mean between 13 and 28 ''primitives per second''.
At first I thought this was because I was using the default sqlite
database on an NFS mount. But, trying sqlite on a local disk and trying
MySQL to separate server both failed to improve performance. I'm getting a
consistent read/write of ~125Kbps/~550Kbps no matter which shapefile or
which database I use.
I cannot see any bottlenecks anywhere, as the two `python /path/to/grass-
gui` processes are averaging 10% of one core combined, the network
utilization is below 10% consistently, and the DB server is almost
quiescent. To give an example of how painful this is:
v.in.ogr dsn=/home/justin/downloads/osm_CA/places.shp
WARNING: All available OGR layers will be imported into vector map
<places>
Check if OGR layer <places> contains polygons...
Importing 7020 features (OGR layer <places>)...
Building topology for vector map <places at OSM>...
Registering primitives...
7020 primitives registered
7020 vertices registered
Building areas...
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 0
Number of primitives: 7020
Number of points: 7020
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
(Fri Jan 31 19:01:08 2014) Command finished (4 min 38 sec)
Note that this may belong under Database.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2185>
