[GRASS-dev] r.stream.* problems on Ubuntu when installed via g.extensions
Markus Neteler neteler at osgeo.org
Sun Feb 2 14:18:24 PST 2014
Hi Johannes,
On Thu, Jan 9, 2014 at 1:25 PM, Johannes Radinger
<johannesradinger at gmail.com> wrote:
> Hi,
> I send this directly to the dev list as I think this is the appropriate list
> for this problem:
> Yesterday I already posted (GRASS-user list) that I get an error (using
> GRASS 7svn) when I tried to launch r.stream.basins which has been installed
> via g.extension (Unable to fetch interface
> description....GRASS_INFO_ERROR(17663,1):Incompatible library version for
> module...).
I forgot to mention that (in Unix/Linux) you can use "ldd" to find the
libraries in use:
# In the GRASS session:
GRASS 7.0.svn> which r.stream.basins
# note the backticks
GRASS 7.0.svn> ldd `which r.stream.basins` | grep grass
Now you can check the dates of those and that of the binary of r.stream.basins.
Additionally: check if more than one binary is around:
sudo updatedb
locate r.stream.basins
Markus
