[GRASS-dev] [GRASS GIS] #2024: r.li.setup generates incomplete r.li conf file
GRASS GIS trac at osgeo.org
Mon Feb 3 12:41:15 PST 2014
 Reporter:  matmar      |       Owner:  rashadkm
     Type:  defect      |      Status:  assigned
 Priority:  normal      |   Milestone:  6.4.4
Component:  Raster      |     Version:  svn-releasebranch64
 Keywords:  r.li.setup  |    Platform:  Linux
      Cpu:  x86-64      |
Changes (by hamish):
 * cc: grass-dev@… (added)
Comment:
 (housekeeping: if you take ownership of a ticket be sure to add the grass-
 dev list back to the cc field; please follow grass_indent.sh conventions)
 what does the 'raster_' variable do?
 as per comment:1, & to avoid double-handling, note that I've made many
 cleanups and fixes for r.li (particularly r.li.setup and its scripts) in
 devbr6 which (erhm, sorry) I have not yet committed or backported to
 relbr64. The job is still a construction site; I haven't forgotten about
 or abandoned it :). fwiw, I notice a couple minor places in the C code
 where I need to sync with trunk too. So more fixes to come, watch this
 space.
 For now I would suggest to focus any r.li testing for 6.x in the 6.5
 development branch. I will continue work on bugfixes for the tcl/bash
 version of r.li.setup there and backport bits to the stable branch once
 they are tested.
 Note newly introduced bashism in sample_area_vector.sh (CAT_LIST[] array)
 in the latest patch. We need to be working the other way to remove them.
 :)  Otherwise thanks, it all helps.
 regards and thanks for your continued patience,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2024#comment:9>
