[GRASS-dev] [GRASS GIS] #2024: r.li.setup generates incomplete r.li conf file
trac at osgeo.org
Mon Feb 3 13:55:09 PST 2014
Reporter: matmar | Owner: rashadkm
Type: defect | Status: assigned
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: svn-releasebranch64
Keywords: r.li.setup | Platform: Linux
Cpu: x86-64 |
Comment(by rashadkm):
Hi Hamish,
I had some more fixes in some r.li. modules which are still not working,
unlike its other friends before. I will do this on devel branch for grass.
IIUC, is there any changes need to reverted?. Because things are almost
running fine and I have no idea about you uncommitted changes. For
r.li.setup I dont have any more changes to push or didnt see any problems
reported. BTW, I would like to add automatic naming for sampling area
(overlay vector option) rather than user input which I think its better to
be in devel branch.
Regarding newly introduced bashism, do you have a fix for it? or should i
do another patch?
raster_ variable: when r.li.setup writes configuration file it write FQN
of the raster map which it should be and when i was testing with some
copies of same map in different mapsets. it reports error like "conf can
only be used with map at landsat not with map. To avoid confusion and provide
a better error results i made the FQN of the input raster map in raster_
variable.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2024#comment:11>
