[GRASS-dev] [GRASS GIS] #2024: r.li.setup generates incomplete r.li conf file
trac at osgeo.org
Mon Feb 3 14:48:23 PST 2014
Reporter: matmar | Owner: rashadkm
Type: defect | Status: assigned
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: svn-releasebranch64
Keywords: r.li.setup | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
I still have a lot of changes to commit to the r.li.setup shell scripts in
devbr6 (the patches are over 650 lines long), so I would ask a little time
to merge those before making any more changes and diverging the code. I
will sync with your patch and look+learn closely at it. I don't have a fix
for the bashism, but I haven't looked to closely at it or if it will
conflict with my changes. I'll sync my changes with what's in svn now, no
need to revert if it's working; my fault for leaving it so long. I
probably shouldn't spend any more time on this today, but I'll look at
syncing the new patch with trunk as a top priority if no one else has done
it first.
(how's the status of wx-r.li.setup in trunk? is the tcl/shell version in
trunk still needed as a reference?)
fwiw I had not backported the num_workers code before because it wasn't
well tested or what I consider properly finished (see comment:1), but I
guess now it is done we'll have to do some more serious testing. i.e. I
wouldn't be surprised if a little more work will be needed, but the
situation should on the whole be better than before, so we're still moving
forward..
for some sort of coordinated plan, I would suggest to focus on trunk to
work on r.li C modules, and devbr6 to work on the r.li.setup tcl/bash
code. I would suggest any new major development to happen in trunk first.
there seemed to be common issues with the C modules around free()ing
memory, I see you've come across the same. All these modules need a good
run through Valgrind.
wrt the 'raster_' variable, my main point is please use self-documenting
variable names. so -> raster_fqn if that's what it is. if there is code
which is not handling map at mapset or without @mapset in the usual grass way
(e.g. the imagery library long had issues with that), we should open new
tickets for that and fix it too instead of cluttering the code by patching
around 3rd party bugs.
thanks both Rashad & Markus for taking it up, r.li has been waiting for
this work for some time!
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2024#comment:13>
