[GRASS-dev] [GRASS GIS] #2185: Painfully Slow 'v.in.ogr' Vector Import
trac at osgeo.org
Mon Feb 3 16:25:46 PST 2014
Reporter: justinzane | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: import, OGR, performance | Platform: Linux
Cpu: x86-64 |
Changes (by justinzane):
* cpu: Unspecified => x86-64
Comment:
Thanks for the response. I cannot post the dot graphs because of size
restrictions, and resizing them makes them near unreadable.
I did another little experiement, and, it seems that the problem is
**not** with the database driver at all. WRT MySQL and SQLite, it is the
location of the 'grassdata' folder that is at issue. I had kept
'grassdata' on an NFS mount. Moving it to a local (btrfs) spinning disk
meant that the import was **many** times faster (although moron forgot to
add 'time' before the command :( ).
I'm rebuilding an unstripped glibc and other dependencies to see exactly
which calls may be problematic.
As far as monitoring the mysql and v.in.ogr processes, do you have any
recommended way besides running grass like:
perf record -e cycles:u -o grass.prof -g -- grass64 -text
/home/justin/maps/grassdata/osm_data/OSM;
# In grass shell [zsh]:
# v.in.ogr dsn=./path/to/shape.shp output=shape
# exit
perf script -i grass.prof | gprof2dot -f perf | dot -Tpng -o output.png;
Ticket URL: <http://trac.osgeo.org/grass/ticket/2185#comment:3>
