[GRASS-dev] [GRASS GIS] #2024: r.li.setup generates incomplete r.li conf file
trac at osgeo.org
Mon Feb 3 22:14:33 PST 2014
Reporter: matmar | Owner: rashadkm
Type: defect | Status: assigned
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: svn-releasebranch64
Keywords: r.li.setup | Platform: Linux
Cpu: x86-64 |
Comment(by rashadkm):
Hi Hamish,
Fine. Take your time to merge those changes and let me know. I will not
touch r.li.setup in grass6 until then. I will work on the C modules now. I
think its better to use grass devbranch rather than grass70. ofcourse i
can provide a corresponding patch for it simultaneously. The reason is
r.li.setup tcl is lacking in grass70 and it would be better to test for
others also if there is everything working. what do you think?
g.gui.rlisetup is still in a state with missing functionality. I had some
patches for it and sent to Luca for reviewing it and he will be updating
g.gui.rlisetup in vienna code sprint (putting up missing parts).
I will provide a new patch with your suggestion for variable naming.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2024#comment:14>
