[GRASS-dev] [GRASS GIS] #2185: Painfully Slow 'v.in.ogr' Vector Import
GRASS GIS trac at osgeo.org
Tue Feb 4 14:11:48 PST 2014
 Reporter:  justinzane                |       Owner:  grass-dev@…
     Type:  defect                    |      Status:  new
 Priority:  normal                    |   Milestone:  7.0.0
Component:  Vector                    |     Version:  svn-trunk
 Keywords:  import, OGR, performance  |    Platform:  Linux
      Cpu:  x86-64                    |
Comment(by justinzane):
 [quote]check the IO traffic on the NFS server without using GRASS[/quote]
 Did, using iotop while running v.in.ogr -- No noticeable IO besides my
 GRASS import, which is expected since it is a personal server.
 [quote]copy some stuff, e.g. an unpacked Linux kernel, from the local disk
 over to the NFS mount and check the performance[/quote]
 Works swimmingly for large files. I updated the post at
 [www.justinzane.com/grass-perf.html] to show a simplistic test. Basically,
 though my Dell laptop has a castrated NIC -- the 4 gigabit pins are not
 connected! -- NFS works at almost line speed. Throughput is not the
 problem, rather it seems to be excessive opens/syncs/similar that is the
 issue.
 Using `nfsstat -Z10`, I get about 27 writes per second. Which seems to
 equate to one write per primitive! I'm a GIS novice, but it seems that
 writing for every primitive is not efficient from a programming
 perspective. Am I missing something?
 [quote]investigate the actually used NFS mount options in
 /proc/mounts[/quote]
 {{{nfs4
 rw,relatime,vers=4.0,rsize=262144,wsize=262144,namlen=255,hard,proto=tcp,port=0,timeo=600,retrans=2,sec=sys,clientaddr=192.168.0.182,local_lock=none,addr=192.168.0.10
 0 0}}}
 [quote]try to tune NFS mount options, particularly rsize,wsize, bigger
 seems to be better, more in man nfs [/quote]
 With writes of a few bytes to a few kB, this does not matter.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2185#comment:8>
