[GRASS-dev] [GRASS GIS] #2188: GRASS fails to start on Windows since r58807
GRASS GIS trac at osgeo.org
Tue Feb 4 19:13:51 PST 2014
 Reporter:  annakrat       |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  critical       |   Milestone:  7.0.0
Component:  wxGUI          |     Version:  svn-trunk
 Keywords:  pygrass, tgis  |    Platform:  Unspecified
      Cpu:  Unspecified    |
 Adding temporal vector algebra (r58807) broke compilation on Windows and
 some Ubuntu machines. During start up it fails:
 Cleaning up temporary files...
 Starting GRASS GIS...
   File "C:\Program Files (x86)\GRASS GIS
 7.0.svn\etc\gui\wxpython\gis_set.py", l
 ine 48, in <module>
     from gui_core.dialogs import TextEntryDialog
 7.0.svn\etc\gui\wxpython\gui_core\dialo
 gs.py", line 49, in <module>
     from gui_core.gselect import LocationSelect, MapsetSelect, Select, \
 7.0.svn\etc\gui\wxpython\gui_core\gsele
 ct.py", line 59, in <module>
     import grass.temporal as tgis
 7.0.svn\etc\python\grass\temporal\__ini
 t__.py", line 29, in <module>
     from temporal_vector_algebra import *
 7.0.svn\etc\python\grass\temporal\tempo
 ral_vector_algebra.py", line 436, in <module>
     m_overlay = pygrass.Module('v.overlay', quiet=True, run_=False)
 7.0.svn\etc\python\grass\pygrass\module
 s\interface\module.py", line 247, in __init__
     raise GrassError(str_err % self.name)
 grass.pygrass.errors.GrassError: "Module 'v.overlay' not found, please
 check tha
 t the module exist"
 Error in GUI startup. If necessary, please report this error to the GRASS
 develo
 pers.
 I will move the tgis import to the places where it's actually needed, so
 it won't be imported when the gui starts. But still I am not sure about
 the other imports in temporal_vector_algebra.py. Can tgis be used without
 pygrass? Is pygrass needed for temporal vector algebra only? The imports
 should be more careful. Also it would be good to understand what's the
 problem with pygrass.Module v.overlay.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2188>
