[GRASS-dev] m.nviz.image - Bad server connection
epi
massimodisasha at gmail.com
Tue Feb 4 22:11:24 PST 2014
i’m tring to generate a 3d image with m.nviz.image, the following command works fine form a ’standard’ GRASS session in text mode on my laptop
but if try to run the same command on a sever while i’m connected via SSH i got the error : Bad server connection
Have you any clue on how to fix this ?
is there any environment var that needs to be exported in order to have m.nviz.image running during an SSH session ?
GRASS 7.0.svn (nc_spm_08_grass7):~ > m.nviz.image \
elevation_map=elevation \
output=elevation_3d \
perspective=15 \
height=2000 \
color_map=elevation \
resolution_fine=1 \
resolution_coarse=1 \
format=tif
ERROR: Bad server connection
Thanks for you help!
Massimo.
