[GRASS-dev] [GRASS GIS] #2024: r.li.setup generates incomplete r.li conf file
trac at osgeo.org
Wed Feb 5 20:17:36 PST 2014
Reporter: matmar | Owner: rashadkm
Type: defect | Status: assigned
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: svn-releasebranch64
Keywords: r.li.setup | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
btw, you might also try osm2pgsql to load the OSM data into a PostGIS
Postgres DB, then live-connect to the PostGIS db with grass 7 with
v.external. for example:
https://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/bin/load_postgis.sh#L85
otherwise map coordinates are stored in $MAPSET/vector in grass's vector
format, and only feature attributes are stored in the DB. Map features are
connected to attributes via category number.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2024#comment:20>
