[GRASS-dev] [GRASS GIS] #2185: Painfully Slow 'v.in.ogr' Vector Import
GRASS GIS trac at osgeo.org
Wed Feb 5 20:18:53 PST 2014
 Reporter:  justinzane                          |       Owner:  grass-dev@…
     Type:  defect                              |      Status:  new
 Priority:  normal                              |   Milestone:  7.0.0
Component:  Vector                              |     Version:  svn-trunk
 Keywords:  import, OGR, performance, v.in.ogr  |    Platform:  Linux
      Cpu:  x86-64                              |
Comment(by hamish):
 btw, you might also try osm2pgsql to load the OSM data into a PostGIS
 Postgres DB, then live-connect to the PostGIS db with grass 7 with
 v.external. for example:
 https://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/bin/load_postgis.sh#L85
 otherwise map coordinates are stored in $MAPSET/vector in grass's vector
 format, and only feature attributes are stored in the DB. Map features are
 connected to attributes via category number.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2185#comment:12>
