[GRASS-dev] [GRASS GIS] #2188: GRASS fails to start on Windows since r58807
trac at osgeo.org
Thu Feb 6 07:11:16 PST 2014
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: pygrass, tgis | Platform: Unspecified
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:2 zarch]:
> Hi Anna,
> Replying to [ticket:2188 annakrat]:
> > Also it would be good to understand
> > what's the problem with pygrass.Module v.overlay.
> [[BR]]
> The problem is that Module try to run:
> get_cmd_xml = subprocess.Popen([cmd, "--interface-description"],
> stdout=subprocess.PIPE)
> But an OSError is raised.
> I've modified the code to give a clearer message and avoid to mask the
original error, see (r58885).
GRASS starts again, however temporal framework is not working because the
original problem is still there. PyGRASS Module class is not working on
Windows (I created ticket #2189). Discussion in #2067 suggests that during
import, no PyGRASS Module should be created which is unfortunately
happening in
[http://trac.osgeo.org/grass/browser/grass/trunk/lib/python/temporal/temporal_vector_algebra.py#L436
temporal_vector_algebra.py].
Ticket URL: <http://trac.osgeo.org/grass/ticket/2188#comment:3>
