[GRASS-dev] [GRASS GIS] #2024: r.li.setup generates incomplete r.li conf file
trac at osgeo.org
Thu Feb 6 19:27:07 PST 2014
Reporter: matmar | Owner: rashadkm
Type: defect | Status: assigned
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: svn-releasebranch64
Keywords: r.li.setup | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
a newline-preserved version of comment:4 can be found here:
Matteo: "below you find a minimum repeatable example that I've done using
the North Carolina GRASS mapset." ...
http://article.gmane.org/gmane.comp.gis.grass.devel/55681
the two sample config files attached to this ticket both have problems.
The first has extra n= s= w= e= chars in them which need to be edited out.
The second is mostly empty (the original topic of this ticket).
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2024#comment:23>
