[GRASS-dev] Major changes in the temporal framework
Luca Delucchi
lucadeluge at gmail.com
Thu Feb 6 23:50:51 PST 2014
On 31 December 2013 03:37, Sören Gebbert <soerengebbert at googlemail.com> wrote:
> Hi Luca,
Hi Soeren
> There are no tests yet that assure the correct function of this
> feature and honestly i don't know what the side effects will be for
> any circumstances, since the principle design is that space time
> datasets are mapset specific, which is well tested and supported. :)
I tested it, and it failed
t.register -i input=tmean_daily_sicilia file=file_raster.txt
start=2012-01-01 increment="1 days"
WARNING: TGIS_DISABLE_MAPSET_CHECK is True
WARNING: TGIS_DISABLE_TIMESTAMP_WRITE is True
Gathering map informations
100%
Register maps in the temporal database
Register maps in the space time raster dataset
ERROR: Only maps from the same mapset can be registered
the input maps inside the text file are written as follow
lst_2012_001_average at modis_lst_reconstructed_europe_daily
> Best regards
> Soeren
Thanks a lot
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
