[GRASS-dev] [GRASS GIS] #2190: Use MySQL Spatial Functionality
GRASS GIS trac at osgeo.org
Fri Feb 7 05:01:19 PST 2014
 Reporter:  justinzane                |       Owner:  grass-dev@…
     Type:  enhancement               |      Status:  new
 Priority:  normal                    |   Milestone:  7.0.0
Component:  Database                  |     Version:  svn-trunk
 Keywords:  MySQL, spatial, geometry  |    Platform:  All
      Cpu:  All                       |
Comment(by mlennert):
 Replying to [ticket:2190 justinzane]:
 > [https://dev.mysql.com/doc/refman/5.0/en/spatial-extensions.html]
 > It appears that MySQL >= 5.0 supports spatial data natively. It would be
 very nice to have GRASS leverage that since MySQL has a wider preinstalled
 base than PostgreSQL.
 What exaxtly do you mean by "leverage" in terms of native spatial data
 support. Generally, GRASS uses its own data format and you can easily
 import from MySQL to GRASS using OGR with v.in.ogr.
 You can also link spatial data in a MySQL database to GRASS via v.external
 (also via OGR).
 If you are speaking about attribute data management, there is a mysql
 driver available in GRASS.
 So AFAIK, the only difference between PostgreSQL and MySQL in their
 treatment by GRASS is the PostGIS direct access driver in GRASS7, which
 only allows to read and write data directly from/to PostGIS (without going
 through OGR), but it does not use any of the other spatial data
 functionalities in PostGIS
 [http://grasswiki.osgeo.org/wiki/PostGIS#Direct_access_to_PostGIS_data_.28GRASS_7_only.29
 1].
 So are you pleading for a similar driver for MySQL, or what exactly are
 you looking for ? I do agree with Hamish, though, that within the GIS
 world, PostGIS is lightyears ahead of MySQL in terms of its adoption for
 spatial data handling.
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2190#comment:3>
