[GRASS-dev] [GRASS GIS] #2192: v.centerpoint: line centers get all cat values from 1 to respective line
GRASS GIS trac at osgeo.org
Fri Feb 7 05:19:50 PST 2014
 Reporter:  mlennert     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.4
Component:  Default      |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 Using v.centerpoint on lines with the output= parameter, resulting lines
 have many cat values, corresponding to all the cat values from 1 to the
 one of the respective line.
 The attached image shows the issue and is the result of the following
 command in the NC dataset:
 v.centerpoint --overwrite input=roadsmajor output=roads_mid lcenter=mid
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2192>
