[GRASS-dev] [GRASS GIS] #2177: g.gui.animation fail to create gif
GRASS GIS trac at osgeo.org
Fri Feb 7 14:06:17 PST 2014
 Reporter:  lucadelu         |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  normal           |   Milestone:  7.0.0
Component:  wxGUI            |     Version:  svn-trunk
 Keywords:  g.gui.animation  |    Platform:  Unspecified
      Cpu:  Unspecified      |
Comment(by annakrat):
 Replying to [comment:6 neteler]:
 > I tried on Fedora 20/64bit using the Pillow fix r:
 > The same error as originally reported.
 > AFAIK Luca uses PIL on Ubuntu while I use python-pillow 2.2.1 on Fedora.
 > Since PIL is no longer developed, Fedora switched to Pillow.
 Luca, are you sure you don't have Pillow on your computer? I have the same
 problem only when I install Pillow. When I uninstall it, it's working
 again. So it looks like it is a Pillow problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177#comment:8>
