[GRASS-dev] Is `typedef struct` considered as a bad practice?
Vaclav Petras
wenzeslaus at gmail.com
Sat Feb 8 19:57:20 PST 2014
Hi C devs,
is following considered wrong in GRASS code?
typedef struct Point {
int x;
int y;
} Point;
/* alternatively */
typedef struct {
int x;
int y;
} Point;
I just saw r58957 and r49886 but till now I thought that typedefs (at the
same time as struct definition) are allowed or even preferred since they
are shorter. From C++ point of view `struct Point` is obsolete syntax which
does not help anybody, both compiler and programmer knows what is Point.
There is nothing about this is SUBMITTING or referred GNU Coding Standards
(at least I don't see anything).
Vaclav
http://trac.osgeo.org/grass/changeset/49886
http://trac.osgeo.org/grass/changeset/58957
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140208/084375f9/attachment.html>
