[GRASS-dev] [GRASS GIS] #1214: r.li.edgedensity: segmentation fault
trac at osgeo.org
Sun Feb 9 02:18:46 PST 2014
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: svn-releasebranch64
Keywords: r.li.edgedensity | Platform: Linux
Cpu: x86-64 |
Comment(by rashadkm):
Replying to [comment:3 hamish]:
> Hi,
> you might test in grass7 where the server/client stuff has been removed
so r.li.daemon is simpler. If that works and 6.x doesn't, it narrows down
where to look.
edegedensity and patchdensity fails for me in grass70 and works in grass65
and grass64
svn revision: 58968
mapset: PERMANENT
r.li.patchdensity map=geology conf=geology_mov output=pdens_out
r.li.edgedensity map=geology conf=geology_mov output=edens_out
geology_mov:
SAMPLINGFRAME 0|0|1|1
SAMPLEAREA -1|-1|0.03571428571428571|0.02631578947368421
MOVINGWINDOW
r.li.patchdensity map=lc96ras conf=lc96_overlay output=pdens_out_overlay
r.li.edgedensity map=lc96ras conf=lc96_overlay output=edens_out_overlay
lc96_overlay:
MASKEDOVERLAYAREA
rli_samp_btest_480|205983.75|205812.75|929030.5031|928916.5031
MASKEDOVERLAYAREA
rli_samp_btest_874|61716.75|61403.25|728333.5031|727963.0031
RASTERMAP lc96ras at PERMANENT
VECTORMAP btest at PERMANENT
btest created from:
v.extract input=boundary_county at PERMANENT output=btest random=3
> Also, to help with reproducibility it would be good if we could all test
with the same data and commands- see the r.li module help page examples or
the r.li/TODO which has a number of usage examples using the standard
sample datasets.
I am using geology map from spearfish60 dataset for moving window
configuration.
For vector overlay option i use the data lc96ras.img mentioned in bug
#2024 comment #4.
> Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1214#comment:4>
