[GRASS-dev] Handling of Python scripts on MS Windows
Helmut Kudrnovsky
hellik at web.de
Mon Feb 10 09:50:14 PST 2014
>GRASS Python scripts are currently executed using the system-wide
>installed Python if it exists. No attempt has been made to explicitly
>use GRASS_PYTHON, therefore it is not possible to say if the system's
>Python would really be completely ignored.
it is (partly) implemented ( and tested on Win7 with a system-wide
ArcGIS-python) at least for python-addons for winGRASS6.4.svn/6.5.svn:
see
http://trac.osgeo.org/grass/ticket/2138#comment:8
and some local tests here shows (see
http://trac.osgeo.org/grass/ticket/2138):
"the python script (which invokes two other python scripts) finishes now."
how to test if the system's Python would really be completely ignored?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Handling-of-Python-scripts-on-MS-Windows-tp5081335p5103005.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
