[GRASS-dev] wxGUI command line: " changed into @ while typing
Vaclav Petras
wenzeslaus at gmail.com
Mon Feb 10 10:53:07 PST 2014
On Mon, Feb 10, 2014 at 1:19 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> I noticed on Linux that while type
> v.extract input=lakes out=anything where=@
> and a map name list pops up...
> Is this happening to anyone else?
> If I understand correctly, you type " character but it is changed to @
character. This does not happen to me with EN and CS keyboard layouts.
GRASS version: 7.0.svn
GRASS SVN Revision: 58850M
Build Date: 2014-01-03
GDAL/OGR: 1.10.0
PROJ.4: 4.8.0
GEOS: 3.3.8
SQLite: 3.7.9
Python: 2.7.3
wxPython: 2.8.12.1
Platform: Linux-3.2.0-58-generic-pae-i686-with-Ubuntu-12.04-precise
> I use
> GRASS SVN Revision: 58873M
> Build Date: 2014-01-04
> GDAL/OGR: 1.10.1
> PROJ.4: 4.8.0
> GEOS:
> SQLite: 3.8.2
> Python: 2.7.5
> wxPython: 2.8.12.0
> Platform: Linux-3.12.9-301.fc20.x86_64-x86_64-with-fedora-20-Heisenbug
> (Un)related: on Windows this seems to work but retrieving the command
> from the wxGUI history by scrolling "eats" the quotes.
> thanks
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140210/30b50528/attachment.html>
