[GRASS-dev] problem bundling GRASS 6.5 and 6.4 RB
Vaclav Petras
wenzeslaus at gmail.com
Mon Feb 10 13:56:19 PST 2014
On Mon, Feb 10, 2014 at 4:08 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
> I did my normal make distclean followed by svn up. I can delete it all
> and have it add it all back in if you think that will help.
> One thing is that it works fine on the machine I compile on, but bombs
> on a different machine.
> I double checked and there is no `UninstallExtensionWindow` in source code
now, except for documentation:
./gui/wxpython/wxpythonlib.dox
Your error is at line 68 in lmgr/frame.py, but there is no
`import...UninstallExtensionWindow` now:
http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/lmgr/frame.py?rev=58946#L68
So, try svn diff, svn status, check your lmgr/frame.py file, check your
packaging process... It seems that the older version of the file is
packaged or perhaps imported from different GRASS on that other machine.
Hope this helps,
Vaclav
Michael
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
> www: http://csdc.asu.edu, http://shesc.asu.edu
> http://www.public.asu.edu/~cmbarton
> On Feb 10, 2014, at 11:51 AM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> On Mon, Feb 10, 2014 at 1:24 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
>> Something else has come up.
>> I compiled GRASS 7 on one computer Friday. It DID bundle OK (but maybe
>> better now?). But when I went to run it on a different computer with the
>> same OS, Python, and wxPython, I hit the following error at startup.
>> Either of you know what this may be? I don't know if it is a bundling
>> issue or something else.
> There was a recent change in GUI related to extensions but it's working
> for me. Have you updated properly? There shouldn't be any
> UninstallExtensionWindow now, it's renamed to ManageExtensionWindow.
> Anna
> GRASS 7.0.svn (nc_spm_08):~ > Traceback (most recent call last):
>> File
>> "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py",
>> line 39, in <module>
>> from lmgr.frame import GMFrame
>> File
>> "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/frame.py",
>> line 68, in <module>
>> from modules.extensions import InstallExtensionWindow,
>> ImportError: cannot import name UninstallExtensionWindow
>> Michael
>> C. Michael Barton
>> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> On Feb 7, 2014, at 5:39 PM, William Kyngesburye <woklist at kyngchaos.com>
>> wrote:
>> > Woops. I deleted too much when I killed the modbuild stuff a few
>> weeks ago. Should be working now.
>> > On Feb 7, 2014, at 6:19 PM, Michael Barton wrote:
>> >> William,
>> >> I just recompiled GRASS 7 and bundled it for distribution. It went
>> fine.
>> >> But when I went to do the same for GRASS 6.5 and 6.4 RB I ran into an
>> odd error.
>> >> Compilation went fine. No errors in either. But bundling bombed with
>> the following error:
>> >> cp -Rf /Library/Python/2.7/site-packages/pyparsing.py
>> /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/macosx/dist/GRASS-6.4.app/Contents/MacOS/etc/python
>> >> sed -i '' -e 's/^GRASS_WXBUNDLED=.*/GRASS_WXBUNDLED=1/'
>> /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/macosx/dist/GRASS-6.4.app/Contents/MacOS/grass.sh
>> >> sed:
>> /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/macosx/dist/GRASS-6.4.app/Contents/MacOS/grass.sh:
>> No such file or directory
>> >> Is there no longer a grass.sh for GRASS 6.x? If not, what do we use to
>> start it?
>> >> The same line does not cause an error for GRASS 7.
>> >> Michael
>> >> C. Michael Barton
>> >> USA
>> >> voice:
>> >> www:
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140210/2fff595b/attachment.html>
