[GRASS-dev] A new error in GRASS 6.4 release branch
Michael Barton
Michael.Barton at asu.edu
Mon Feb 10 14:16:46 PST 2014
I just tried to compile GRASS 6.4 a few minutes ago. A new error has cropped up over the weekend. I’m compiling with a completely new copy of the source code. It is missing a PNG file
GRASS GIS compilation log
Started compilation: Mon Feb 10 14:46:41 MST 2014
Errors in:
/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/general/g.parser
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Mon Feb 10 15:00:19 MST 2014
make: *** [default] Error 1
cmb-shesc-imac:grass64_rb cmbarton$ cd /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/general/g.parser
cmb-shesc-imac:g.parser cmbarton$ make
Makefile:20: warning: overriding commands for target `htmlcmd'
../../include/Make/Html.make:45: warning: ignoring old commands for target `htmlcmd'
/Applications/Xcode.app/Contents/Developer/usr/bin/make htmlcmd
/Applications/Xcode.app/Contents/Developer/usr/bin/make /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/dist.x86_64-apple-darwin13.0.0/docs/html/g.parser.html HTMLSRC=
make[2]: `/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/dist.x86_64-apple-darwin13.0.0/docs/html/g.parser.html' is up to date.
/Applications/Xcode.app/Contents/Developer/usr/bin/make mancmd
/Applications/Xcode.app/Contents/Developer/usr/bin/make /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/dist.x86_64-apple-darwin13.0.0/man/man1/g.parser.1 MANSRC=/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/dist.x86_64-apple-darwin13.0.0/docs/html/g.parser.html
make[2]: `/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/dist.x86_64-apple-darwin13.0.0/man/man1/g.parser.1' is up to date.
/usr/bin/install -c -m 644 g_parser_test.png /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/dist.x86_64-apple-darwin13.0.0/docs/html/g_parser_test.png
install: g_parser_test.png: No such file or directory
make: *** [default] Error 71
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140210/fe25de03/attachment.html>
