[GRASS-dev] wxGUI command line: " changed into @ while typing
Anna Petrášová
kratochanna at gmail.com
Mon Feb 10 17:58:12 PST 2014
On Mon, Feb 10, 2014 at 5:07 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Feb 10, 2014 at 10:49 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> > On Mon, Feb 10, 2014 at 3:25 PM, Anna Petrášová <kratochanna at gmail.com>
> > wrote:
> >> On Mon, Feb 10, 2014 at 2:28 PM, Markus Metz
> >> <markus.metz.giswork at gmail.com> wrote:
> >>> On Mon, Feb 10, 2014 at 7:53 PM, Vaclav Petras <wenzeslaus at gmail.com>
> >>> wrote:
> >>> > On Mon, Feb 10, 2014 at 1:19 PM, Markus Neteler <neteler at osgeo.org>
> >>> > wrote:
> >>> >> Hi,
> >>> >> I noticed on Linux that while type
> >>> >> v.extract input=lakes out=anything where=@
> >>> >> and a map name list pops up...
> >>> >> Is this happening to anyone else?
> >>> > If I understand correctly, you type " character but it is changed to
> >>> > character. This does not happen to me with EN and CS keyboard
> layouts.
> >>> The " character is changed to @ for me too on a DE keyboard layout.
> >> Could someone test the attached diff please?
> > Sorry, new better diff attached.
> Locally applied, it helps and the " is "generated" as expected.
> Only scrolling back and forth in the wxGUI cmd line history eats the "
> up but that probably unrelated.
yes, that's unrelated, I remember I looked at it once, but I am not really
sure what was the problem...
The quotes issue is fixed in r58984 for GRASS 7 and backported
Anna
> markusN
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140210/e625484f/attachment.html>
