[GRASS-dev] problem bundling GRASS 6.5 and 6.4 RB
William Kyngesburye
woklist at kyngchaos.com
Tue Feb 11 12:00:44 PST 2014
Are you really running it from the source thru Dropbox on the other Mac? When running from source, the bundling hasn't happened yet, and maybe the other Mac is trying to use a different wxpython. To get GRASS binaries transferred to another Mac you need to make the bindist installer and install from that on the other Mac.
On Feb 11, 2014, at 11:27 AM, Michael Barton wrote:
> I just realized that I did not list the entire error message. More clues at the end of it. I DO have GISDBASE set--and reset it just to be sure. Has here been a change to the configuration files and/or the way/place they are stored?
> Michael
> ======= error message again =========
> Launching <wxpython> GUI in the background, please wait...
> ERROR: Incompatible library version for module. You need to rebuild GRASS
> or untangle multiple installations.
> Traceback (most recent call last):
> File "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/prompt.py", line 11, in <module>
> gettext.install('grasslibs', os.path.join(gisenv['GISDBASE'], 'locale'), unicode = True)
> KeyError: 'GISDBASE'
> GRASS 7.0.svn (nc_spm_08):~ > ERROR: Incompatible library version for module. You need to rebuild GRASS
> File "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py", line 39, in <module>
> from lmgr.frame import GMFrame
> File "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/frame.py", line 50, in <module>
> from lmgr.layertree import LayerTree, LMIcons
> File "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/layertree.py", line 37, in <module>
> from mapdisp.frame import MapFrame
> File "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/mapdisp/frame.py", line 40, in <module>
> from vdigit.toolbars import VDigitToolbar
> File "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/vdigit/toolbars.py", line 23, in <module>
> from gui_core.dialogs import CreateNewVector, VectorDialog
> ImportError: cannot import name VectorDialog
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice:
> 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Feb 11, 2014, at 10:23 AM, Michael Barton <michael.barton at asu.edu> wrote:
>> I rebuilt and rebundled GRASS 7 yesterday evening. I started from a completely clean update (deleted all source files and did an svn up to restore then all with new ones).
>> There were no errors in compiling and building. BUT, I have a LOT or errors trying to run this from a different box than the one I compiled on. Any thoughts would be helpful. I'll keep experimenting to see if this is a problem in compiling or bundling.
>> Michael
>> ========== errors below ===============
>> Welcome to GRASS 7.0.svn
>> GRASS homepage: http://grass.osgeo.org
>> This version running through: Bash Shell (/bin/bash)
>> Help is available with the command: g.manual -i
>> See the licence terms with: g.version -c
>> If required, restart the GUI with: g.gui wxpython
>> When ready to quit enter: exit
>> C. Michael Barton
>> voice:
>> On Feb 10, 2014, at 3:31 PM, Michael Barton <michael.barton at asu.edu> wrote:
>>> I’m starting from a clean update of GRASS 7 source from the SVN. I’ll let you know.
>>> Michael
>>> ______________________________
>>> C. Michael Barton
>>> Tempe, AZ 85287-2402
>>> USA
>>> voice:
>>> fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
>>> www:
>>> http://csdc.asu.edu, http://shesc.asu.edu
>>> On Feb 10, 2014, at 2:56 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>>>> On Mon, Feb 10, 2014 at 4:08 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>>> I did my normal make distclean followed by svn up. I can delete it all and have it add it all back in if you think that will help.
>>>> One thing is that it works fine on the machine I compile on, but bombs on a different machine.
>>>> I double checked and there is no `UninstallExtensionWindow` in source code now, except for documentation:
>>>> ./gui/wxpython/wxpythonlib.dox
>>>> Your error is at line 68 in lmgr/frame.py, but there is no `import...UninstallExtensionWindow` now:
>>>> http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/lmgr/frame.py?rev=58946#L68
>>>> So, try svn diff, svn status, check your lmgr/frame.py file, check your packaging process... It seems that the older version of the file is packaged or perhaps imported from different GRASS on that other machine.
>>>> Hope this helps,
>>>> Vaclav
>>>> Michael
>>>> C. Michael Barton
>>>> USA
>>>> voice:
>>>> www:
>>>> On Feb 10, 2014, at 11:51 AM, Anna Petrášová <kratochanna at gmail.com> wrote:
>>>>> On Mon, Feb 10, 2014 at 1:24 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>>>> Something else has come up.
>>>>> I compiled GRASS 7 on one computer Friday. It DID bundle OK (but maybe better now?). But when I went to run it on a different computer with the same OS, Python, and wxPython, I hit the following error at startup.
>>>>> Either of you know what this may be? I don't know if it is a bundling issue or something else.
>>>>> There was a recent change in GUI related to extensions but it's working for me. Have you updated properly? There shouldn't be any UninstallExtensionWindow now, it's renamed to ManageExtensionWindow.
>>>>> Anna
>>>>> GRASS 7.0.svn (nc_spm_08):~ > Traceback (most recent call last):
>>>>> File "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/frame.py", line 68, in <module>
>>>>> from modules.extensions import InstallExtensionWindow, UninstallExtensionWindow
>>>>> ImportError: cannot import name UninstallExtensionWindow
>>>>> Michael
>>>>> C. Michael Barton
>>>>> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
>>>>> On Feb 7, 2014, at 5:39 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
>>>>> > Woops. I deleted too much when I killed the modbuild stuff a few weeks ago. Should be working now.
>>>>> > On Feb 7, 2014, at 6:19 PM, Michael Barton wrote:
>>>>> >> William,
>>>>> >> I just recompiled GRASS 7 and bundled it for distribution. It went fine.
>>>>> >> But when I went to do the same for GRASS 6.5 and 6.4 RB I ran into an odd error.
>>>>> >> Compilation went fine. No errors in either. But bundling bombed with the following error:
>>>>> >> cp -Rf /Library/Python/2.7/site-packages/pyparsing.py /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/macosx/dist/GRASS-6.4.app/Contents/MacOS/etc/python
>>>>> >> sed -i '' -e 's/^GRASS_WXBUNDLED=.*/GRASS_WXBUNDLED=1/' /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/macosx/dist/GRASS-6.4.app/Contents/MacOS/grass.sh
>>>>> >> sed: /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/macosx/dist/GRASS-6.4.app/Contents/MacOS/grass.sh: No such file or directory
>>>>> >> Is there no longer a grass.sh for GRASS 6.x? If not, what do we use to start it?
>>>>> >> The same line does not cause an error for GRASS 7.
>>>>> >> Michael
>>>>> >> C. Michael Barton
>>>>> >> USA
>>>>> >> voice:
>>>>> >> www:
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
