[GRASS-dev] [GRASS GIS] #1416: wingrass7 nightly build crash on start
trac at osgeo.org
Sun Feb 16 19:49:48 PST 2014
Reporter: MilenaN | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Startup | Version: svn-trunk
Resolution: worksforme | Keywords: encoding
Platform: MSWindows 7 | Cpu: x86-64
Changes (by wenzeslaus):
* keywords: => encoding
* status: new => closed
* resolution: => worksforme
Comment:
Although, it is hard to say if this encoding error was fixed, no activity
and no further reports, so closing this ticket as worksforme, so there are
some people here and there running localized GRASS 7 on MS Windows.
Reopen if the the error is the same, create a new one if the error is
different. Please try to make ticket summary less general, e.g. use end of
the Python traceback (''WinGRASS 7 nightly build crash on start with
UnicodeDecodeError''). Use `{{{` and `}}}` to separate tracebacks or any
other errors from your text in the report. However, thanks for your
reports in any form.
Good comment about ''Hit RETURN to continue'', create a ticket for it if
you think that it should be changed (and discuss some translation if
possible).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1416#comment:2>
