[GRASS-dev] [GRASS GIS] #1214: r.li.edgedensity: segmentation fault
trac at osgeo.org
Mon Feb 17 02:49:22 PST 2014
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: svn-releasebranch64
Keywords: r.li.edgedensity | Platform: Linux
Cpu: x86-64 |
Comment(by mmetz):
Replying to [comment:4 rashadkm]:
> Replying to [comment:3 hamish]:
> > Hi,
> > you might test in grass7 where the server/client stuff has been
removed so r.li.daemon is simpler. If that works and 6.x doesn't, it
narrows down where to look.
> edegedensity and patchdensity fails for me in grass70 and works in
grass65 and grass64
> svn revision: 58968
> location: nc_spm_08
> mapset: PERMANENT
r.li.patchdensity map=geology conf=geology_mov output=pdens_out
r.li.edgedensity map=geology conf=geology_mov output=edens_out
> geology_mov:
SAMPLINGFRAME 0|0|1|1
SAMPLEAREA -1|-1|0.03571428571428571|0.02631578947368421
MOVINGWINDOW
r.li.patchdensity and r.li.edgedensity pass the test with trunk r59072.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1214#comment:6>
