[GRASS-dev] Trac custom fields: Platform
Maris Nartiss maris.gis at gmail.com
Mon Feb 17 04:09:39 PST 2014
Hello all,
I would like to propose to merge all MS Windows platforms into one.
Rationale - most of MS Windows problems are specific to more than one
version. Issues concerning only single version are minority vs the
rest (hint - some of issues are marked as single platform specific
because lack of testing on different configurations for other Windows
versions).
Also - there is a single MacOS platform and single Linux platform to
account everything from Debian on i386 to Gentoo on SPARC.
Specific Windows versions can be keyworded thus allowing to mark all
affected versions not only one selected as "platform".
In a hope of discussion and change,
Maris.
2014-02-02 23:29 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
>>>  Done, it is set in
>>>  /var/www/trac/grass/conf/trac.ini
>> ... as documented in
>> http://wiki.osgeo.org/wiki/Trac_Instances#Custom_fields
>> Posted here to find it back next time :-)
> thanks Markus. Martin
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
