#2041: wxgui: error attempting to display imported raster map that was imported as
three bands
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: raster import display | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:2 mlennert]:
> Replying to [comment:1 wenzeslaus]:
> > As a temporary solution, GUI currently contains a text that says that
''Add layers...'' may not work with multiple bands.
> I guess to get a "real" solution, the dialog would have to run gdalinfo
first to check whether there are multiple bands in the file ?
This is not enough, you would also need to check if the band option or the
k flag is used with r.in.gdal.
In order to keep things sufficiently simple (which the wxGUI not longer
is, but anyway), I would rather suggest to test if the output raster
exists, if not, the GUI should not attempt to display it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2041#comment:3>
